This is usually caused by Ice building up and then melting. If you have a unit where there is ice building up you may have to leave the unit to completely defrost.
The drawers will pull out the front, then you can unclip the drawer fronts, they are just held together by plastic tabs. GE Refrigerator Drawer WR32X10338
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
