Battery out, powering down. Holding button in on and off mode.
You can format the internal card, see Manual
Olympus Stylus 770 SW Instruction Manual
Search for internal Memory
SOURCE: Playback modes
There are playback modes such as single-frame, Index (you can select the number of frames to display on the monitor from 4, 9 or 16 frames), Close-up (2x through 10x magnification), Slideshow (display the stored images one after another in succession) or playback images by rotating.
SOURCE: Saving zoom in photos
You can't. The inphoto digital zoom is just so you can do it. The best thing to do is download the photo to your computer and then use the camera software to zoom/crop etc. Then you can save the altered image.
SOURCE: Playback mode not working,
do the pictures get stored on the card? (check this with a card reader on a computer...)
SOURCE: playback
In playback mode, with each new picture, press the central "OK" button, the words go away. With the next picture, you need to do the same..so,with each new pic, you need to press the "OK" button. I had the same problem!
SOURCE: push on button camera doesnt budge but playback is okay!
I have this problem. PLease send me solution. THX
"Protecting Photographs from Deletion
In full-frame, zoom, and thumbnail playback, the button can be used to protect photographs
from accidental deletion. Protected files can not be deleted using the button or
the Delete option in the playback menu, and have DOS "read-only" status when viewed on
a Windows computer. Note that protected files will be deleted when the memory card is
formatted"
This is from the nikon website. You can down load the entire users manual here:
http://www.nikonusa.com/pdf/manuals/dslr/D40X_en.pdf
