Sennheiser ew100 wireless transmitter. Mute switch used to work fine. Now does not mute when switched on.
SOURCE: on/off button broken
You should'nt need a scematic, this happens all the time with the ew100 handhelds. you will need to remove the three star bit screws between the screen and the batteries, pull off the end cover and with a small screwdriver or some long needle nose pliers- put the red button back into the hole from the inside of the cover. Just take care when putting the end cover back on- sometimes its a bit difficult.
Goodluck
PTB.
SOURCE: Microphone doesn't work on Logitech ClearChat
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
SOURCE: AKG PT 80 transmitter stopped transmitting.
So that means the microphone has a problem with the strength of it's signal, which means it has to be serviced. Not sure if it's cost effective, make sure you get an estimate if you choose to have it serviced. Often, it's better to just buy a new one, unless you can fix it yourself.
SOURCE: on/mute/off switch on shurepg58 wireless mic will
It sounds like it needs to be sent to Shure for repairs.
SOURCE: I have an ew100 wireless
There should be 2 MUTE buttons, one on the mic transmitter and one on the body pack transmitter.
It sounds like one of them is on all the time.
Otherwise it may be that your SQUELCH setting is wrong. Try adjusting that to between 5-15 db.
Here is a link to the Sennheiser Online Support FAQ page about squelch problems but the detailed instructions should be in your User's Manual.
http://www.sennheiser.ca/live/senn/faq/en/14#q88
And here is the Main support page for your EW100 unit:
http://www.sennheiser.ca/live/senn/produit/en/1132
and here is the direct link to your ONLINE USER'S MANUAL:
http://www.sennheiser.ca/live/prod_download/ew100-ENGG3_InstructionsForUse_EN.pdf
Sometimes the MUTE is displayed when the receiver is not getting any radio signal (see page 8 and page 22 of the online user's manual). Again try lowering the squelch.
Good luck and please comment back and rate if this was at all helpful.
Thanks.
Joe.
