Washing Machines Logo
A
Anonymous Posted on Feb 13, 2015
How do I install a replacement diaphragm in a splendide wd2100
Can't get the new seal on around the drum
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jan 14, 2008
SOURCE: Non-operational in RV when Onan generator and Xantrex inverter are on
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
Anonymous
  • Posted on Jun 25, 2010
SOURCE: We have a Splendide WD2100 washer/dryer
I had the same problem and ordered one from Westland Sales. Phone No: 503-655-2563 Ext. 5 for parts. I believe I spoke to a gentleman named Terry. I just received mine today, cost was $52.00 including shipping.
Anonymous
  • 298 Answers
  • Posted on Dec 15, 2010
SOURCE: How do I remove and
you can go to applinancerepairplanet.vstore.ca for a sevice manual on this to help you in this mater.
Anonymous
  • 6277 Answers
  • Posted on Mar 03, 2011
SOURCE: Have a splendide 2000 w/d
You need to either find a spares supplier from your telephone directory (in the UK the 'commercial' directory is called Yellow Pages) OR stay on line and carry out a search. Type in 'splendide washer spares' and, with a bit of luck, you should be presented with sources for purchasing on-line or from 'real' shops.
Sorry we cannot do this for you.
Good luck,
John C
Anonymous
  • 2605 Answers
  • Posted on Aug 21, 2011
SOURCE: I need a door handle for the wd2100 splendide
Hello, welcome to FixYa.
To address your concern on Splendide parts availability on-line, you can check out these folks.
Westland Sales.
They are the primary place in North America for these parts for Splendide/Ariston...to my knowledge.
web, http://www.westlandsales.com/
or phone, 1-800-356-0766
Let me know if I can help further in any manner and I will do what I can. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
I have a Splendide 2000 s it will fill up with water and drain the drum does not turn and the control setting knob is going around
Drum motor brushes worn would be my first check. Does the drum spin freely by hand? If not then drum bearings are shot.
My splendide leaks into the drum when not in use. Drips about 1/2 gal per day. What may be broken?
faulty diaphragm in the water control solenoid
easy fix is to turn off the tap when not in use
2helpful
2helpful
2answers
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
We have a Splendide WD2100 washer/dryer combination. The main door handle is broken and I need a replacement handle
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
2answers
Replacement of a porthole diaphragm on a 802M splendide washer dryer
Remove the top and loosen the clamp around the spin tub. Remove the two screws on the hinge on the door to get it out of the way. remove the clamp around the diaphram in the door. This will require 3 arms and a trained monkey! Seriously, get 2 screwdrivers andat least one pair of pliers as this is hard! Slip a screwwdriver under the ring between the rubber folds. Slip another one opposite from this one and use a pliers to pull the ring free. Its hard but you can do it. Reverse the process when installing the new one. Make sure you have already aligned the inside up top for the air vent for the dry tube. Use a zip tie to seal that part around the dryer vent tube. Tighten the inside clamp before putting the ring back on the front! Have fun!
3answers
Maytag Neptune MDE9700AYW
We have the same machine. The drum also broke so we had it professionally installed. It wasn't done well enough and after the 90 day repair warranty, other problems developed. We still don't have a dryer and the next repair is $500 as other parts were damaged and we didn't catch it within the 90 days.
Bottom line: do have it professionally installed but be sure to ask about their work guarantee. As soon as you have any problem at all, call them back.
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
