My kids were playing with playstation on lg 52'' plasma tv and now it keeps shutting off and when i can get it to turn on it is bright screen of colors
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Check the voltage from the power regulator section. If it is more than normal by 4 to 5 volts, this kid of fault can occur. If it is the reason, the brightness of the picture will be high too.
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
It's actually similar to the old screen burn in you'd see on very old CRT televisions and monitors. You can play your playstation on it, just make it a point not to leave it on the same screen for long periods. For instance, if you pause the game, turn the TV off until you're ready to continue.
Plasma Burn In only happens if you leave the same image on the screen for an extended period. Just don't do that, and you'll be fine.
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
