Tried a charged battery and AC. Still dead. Worked fine until battery ran out, then would failed to power up. Cam only has 81 hours on it.
SOURCE: flashing red power light
The problem here is condensation inside the camera. I leave the camera turned off, remove the cassette tape and then point a hair drier on warm or low heat and slow speed right into the innards of the camera through the open cassette tape door. I run the hair dryer for 5 minutes and then replace the cassette. If the camera still dosen't work just wait for another 5 or 10 minutes and then it will work OK.
SOURCE: panasonic SDR H20 camcorder
Hi There, You probably have a blown out fuse. Unless your a service tech with a service manual, it may be hard for you to locate where the fuses are. A panasonic service depot could give you a proper estimate.
Thanks, mr cicmo
SOURCE: Panasonic 26X Optical Zoom PV-GS31 Camcorder Power on Problem
One or two parts are most likely faulty. They are fairly easy to replace.
One is the power unit on back where all connectors are made to the unit. The other is a small board right next to the power unit and has the on board battery for date and time. Hardest part of the repair is removing the case. The power unit is on sale on e-bay. The other part may be harder to find, but not impossible.
SOURCE: Charging Panasonic NV-DS38
Yes that is correct.
You have to use a separate charger as the "DC in" socket is on the camera body underneath the battery.
SOURCE: Panasonic AG DVC30 purchased on ebay. Getting
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
