Already explained
Maybe you have a broken plastic tab on the inside of the agitator that is causing the agitator to rock back and forth. if you don't have the agitator pushed all the way on, you should see it lift up when unit fills with water. Might even be rubbing against the bottom of the lid if it lifts high enough.
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
