Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My signal is weak or lost. Help.
TV is a sony bravia, a 32" I haven't tried anything yet as this is not MY tv.
    Top Expert:
  • Sony Master
  • 76,171 Answers
Contact any service technician or the authorized service center for Sony. http://electronicshelponline.blogspot.com/
Posted on Feb 14, 2015
6ya staff
SOURCE:
Sony 32 inch TV keeps shutting down on BBC 1 ? why
Hi
at HDMI may be some signals are disturbing the tv at BBC1 so please try to change the HDMI setting if the problem goes then ok other wise you may connect your tv box through AV
Feb 14, 2015 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
Was trying to install new dvd and now have lost tv signal by trying to get proper setup for dvd. Did not get dvd to work and now tv screen lists no signal tried several times to reset tv but cannot.
Buy and replaced it with a new HDMI cable to the DVD player for better function.Tries unplug the tv about an hour,replug it back in.Goto tv menu,goto PICTURE.Go down to reset the Tuner board back to Facrory setting.The tv should have signal now.Not than the tv Tuner board have problems,must be change,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 16, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony BRAVIA KDL-V32XBR2 32 has lost its sound. I have checked that the speaker setting is on, the mute is off. Is there anything elsei I can check?
please try differect sources e.g. dvd, cable TV box, aerial. Also check that your connectors are properly plugged in. If none of those work, bring your tv to the nearest service center.
cheers!
Jul 11, 2009 | Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
My Sony Bravia KLV-32U300A 32 in. HDTV-Ready LCD TV just lost the picture. Just see different colors. Hears static sound from the back of the unit. This was a progression. Few days ago, clicking sound...
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
Apr 19, 2009 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
