If the laptop has no HDMI port, the forget the whole HDMI thing cause getting it through that port when the laptop or desktop is not made for it will end up costing as much as a new computer altogether. You need to find out if the laptop has any Composite or Component outputs. Those are relatively easy to spot. a Composite output is usually a RCA jack and also usually colored yellow, and goes into the yellow RCA port on your TV next to the red and white RCA ports which are the left and right sound channels. The Component outputs are also RCA jacks, but are usually red green and blue cause each wire sends its own color to make up the TV's image. They will also go on the back of your TV near all the other RCA ports. Wether your TV has just HDMI and no other porte or not, or if it has either Composite or Component inputs or both, that i don't know cause i don't know what your TV is. As for the sound, if you also want it on the TV, you just need to go to the local electronics store and buy an adapter/wire that goes from a 1/8 stereo headphone jack to 2 RCA jacks on the other side, one being white and the other being red. See where i'm going with that?:P Plug the 2 RCA jacks from the wire you bought into the TV in the corresponding inputs that go with the input you plugged the image in, and the 1/8 stereo jack into the headphone output of your laptop.
It sounds like you did some good testing by taking your xbox to a friend's home and trying it with his TV and HDMI input. You can try a reset on your Panasonic TV and see if that restores the HDMI input functions. Note this will erase your programmed TV channels so you'd need to re-enter those.
Unplug the TV for at least 15 minutes
Plug it back in and you'll be prompted to go through the initial setup just like when the TV was new.
If after that you still have no HDMI function on any of the inputs, that would indicate the set needs some service by a technician.
You will need standard HDMI only if your laptop have HDMI port. I think hp 6510b not include HDMI port. It has VGA and SVEDIO Output. Your toshiba TV have many PC INPUT Ports such as S-Vedio, D-sub , VGA like old Desktop PC connection with Projector). So buy VGA cable or S-vedio Cable, then you can connect.
Your laptop does not have HDMI port only VGA, you have two choices check if your TV has a VGA port and if it does you can connect the laptop to the tv (you will need a vga cable.) if tv doesnt have VGA connector then you could try finding a USB to HDMI adaptor for example: http://www.cooldrives.com/index.php/usb-hdmi-adapter-dvi.html
You can use either an HDMI cable or a VGA cable to connect your computer to your TV. Your computer has both HDMI and VGA ports. You can use either ports but you cannot use both or else your video card will crash.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
THE ACER ASPIRE 5738 HAS AN HDMI PORT ON THE LEFT HAND SIDE. BUY AN HDMI LEAD AND CONNECT IT TO YOUR LAPTOP AND HDMI PORT ON YOUR LCD.SELECT HDMI AS INPUT ON YOUR LCD AND HEY PRESTO JOB DONE
