Inspect
Wireset
Damaged, worn, or deteriorating spark plug or coil wire(s).
in this list u will find a answer to ur problem Shaun
Inspect
Spark Plug
Fouled, damaged or broken spark plug(s).
Inspect
Fuel Filter
Clogged or dirty fuel filter
Inspect
Distributor
Worn, loose or incorrectly adjusted distributor.
5
Inspect
Distributor Cap
Loose or cracked distributor cap
6
Inspect
Distributor Cap And Rotor Kit
Loose, cracked, or worn distributor cap and ignition rotor.
7
Inspect
PCV Valve
Plugged or damaged pcv valve.
8
Inspect
Air Filter
Restricted or clogged air filter.
9
Inspect
Catalytic Converter
Clogged, damaged, defective or faulty catalytic converter.
10
Inspect
Automatic Transmission
Improperly adjusted kickdown cable adjustment or internal transmission problems.
11
Inspect
Fuel Pump
Improperly functioning fuel pump or circuits.
12
Inspect
MAP Sensor
Improperly connected or faulty m.a.p. sensor.
13
Inspect
Mass Air Flow Sensor
Improperly connected or faulty mass air flow sensor.
14
Inspect
Throttle Position Sensor
Faulty throttle position sensor or throttle position sensor circuit.
15
Inspect
Timing Specification
Incorrectly adjusted engine timing.
16
Inspect
Fuel System Pressure
Incorrect fuel pressure being delivered to carburetor or fuel injection system.
