I installed fresh batteries and this had no effect.
Depending on the TV model, there were some where the IR (Infrared) board inside the TV failed. It is not the remote that failed. You can test the remote by trying it at a Best Buy store on some of their TV's. If you are somewhat handy, you can easily remove the IR board and send it into a repair service that I located on E-Bay. There was repair service in Indiana and one in California. I sent it to the California and it came back in less than 1 week. I installed it and the TV works fine now.
SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
SOURCE: My Sony Bravia KDL-40D3000 no longer responds to
Remote sensor seems bad in your KDL-40D3000 that will be replaced because it is unable to receive remote infra red signals and remote has been tested on other tv and found good.
Please replace remote sensor in tv to get it fixed, local tech will help you to solve this problem.
Thanks.
SOURCE: My Sony Bravia is stuck on channel 2 and won't
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
