Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
A
Anonymous Posted on Feb 15, 2015
How to replace dryer drum dividers
Nothing
  • Jorgie  the appliance guy
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How many cubic feet is my kenmore dryer model 110.79812990
The capacity of a dryer is measured by its drum volume in cubic feet. Measure the depth of the dryer from the back to the door opening. Measure the diameter of the dryer. Divide the diameter by two to find the radius. Calculate the size of the dryer by squaring the radius and multiplying by the depth.
Kenmore dryer 86984810
pi r squared * depth to calculate this mathematically. Get a tape measure and measure the distance of the center of the drum to the edge, multiply that by itself. Then multipky that by 3.14. then measure from the back of the drum to the front edge and multiply by that. For example the dryer is 24 inches deep and has a 12 inch radius. 12 times 12 is 144 times 3.14 this is 452.16 times 24 equals 10851.84 cubic inches. divide that by 1728 to get cubic feet. You can do this in feet instead so it is easier. http://www.ehow.com/how_5622710_measure-dryer.html
Jul 09, 2013 • Dryers
Problem with Washing Machines Something stuck /rattling in washing machine plastic divider Inside drum
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Where are the fuses located in the Maytag DE713C
by the element on the rear upper left side of the dryer. lift the top up and you'll see them behind the dividing wall where the rear pf the drum sits
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
MY DRYER HEATS ALL THE TIME IT IS PLUGGED IN..I HAVE TO KEEP IT UNPLUGGED SO IT WON'T HEAT..IT HAS GOTTEN SO HOT THAT IT HAS MELTED PART OF ONE OF THE PLASTIC DIVIDERS IN THE DRUM..WHAT WOULD BE THE...
This could potentially be a very dangerous situation. If you would forget, leave clothes or something else flammable on top of the dryer and leave the dryer plugged in, you could come home to a house burned to the ground, not even considering what could happen if someone was in the home at the time. If it has been hot enough to melt one of the clothes tumblers inside the drum, it could, conceiveably have been hot enough to have melted some of the insulation off some of the wiring inside the unit. The only way to tell for sure would be to disassemble the unit to have it inspected, which could cost a fair sized bill in itself, not to mention what it could cost to replace that wiring. In light of this I would suggest just starting a search for a new dryer. Sorry.
1helpful
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 • Dryers
2helpful
2 of the 3 dividers in the dryer drum has come off. How do I screw them back in?
You have to disassemble the dryer partially to get the dividers back on.
There are two screws holding the door on, and it is slightly hooked in, take it off.
Take off the two screws on the opposite side.
Remove the front panel, pull out lift off tabs on bottom.
There are two hooks at top corners holding top down, 5/16 bolts I think on each side.
This allows room to reattach dividers when you raise top up, screws that came out should be laying on bottom of dryer. About two in each one, find four screws. Turn drum by hand to align for reattaching the dividers.
Important that you have unplugged and watch out for sharp edges.
2answers
Bra wire stuck between the drums in hotpoint WD440 Aquarius washer dryer
Look all around the inner tub with a torch , if you spot the wire sticking through grasp it firmly with pliers and pull out , dont let it go , if it slips completely between drums it is more difficult to get to.
2answers
My neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Hello
Welcome to Fixya
My name is Huum,
You said, my Neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Those are the screws that hold the dividers to the drum.
The drum ha to come off to replace them. Big job!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
