Dryers Logo
h
hersey purvis Posted on Feb 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the thermal fuse on haier dryer rde350aw located
Not heating
Fran Roles
Level 2:
Scholar:
New Friend:
  • Expert 88 Answers
  • Posted on Feb 15, 2015
Fran Roles
Expert
Level 2:
Scholar:
New Friend:
Answers
88
Questions
0
Helped
49121
Points
165
Inside the back attached to the exhaust plenum.
Where is the thermal fuse on Haier Dryer model HLTD600AEW?
The location of the thermal fuse on a Haier Dryer model HLTD600AEW may vary depending on the specific model and design of the dryer. However, in general, the thermal fuse is usually located near the heating element or the exhaust duct. It may be hidden behind a panel or tucked away in a hard-to-reach area. In some cases, it may be necessary to consult the user manual or contact the manufacturer for specific instructions on how to locate the thermal fuse on a Haier Dryer model HLTD600AEW.
Where is the thermal fuse located on a Haier RDE350AW dryer ?
Not exactly a fuse for drying heat, the electric motor would have a thermal fuse strapped into the winding.
The dryer exhaust hot air chimney, just after the drum, would have both a thermostat and a high heat limit called thermodisk cut off and clixon by trade name.
Find the wiring diagram inside the dryer panels to reveal color wires going to what you need finding.
My Haier Dryer Model RDE350AW only clicks when I press start button, any suggestions?
Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
1helpful
Where is the thermal fuse on haier rde350aw ?
Either on the heating element or right next to the blower fan
Nov 05, 2014 • Dryers
Haier dryer rde350aw not drying?
The heating element probably needs to be replaced. The are not hard to fix or very e
Aug 07, 2014 • Dryers
MODEL # RDE350AW HAIER HAS POWER BUT WONT START MAKES CLICKING SOUND
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
My haier dryer quit. I replaced the thermostat located in back near the heating element and the thermal limiter. The dryer worked twice but seemed to get very hot. The on the third time it quit again. What...
Have you made sure the vent is not plugged, and that the vent fan is working properly? This would cause over heating. There is also a thermal fuse that caused it to quit again.
Top Haier Dryers Experts
Mike Cairns
Mike Cairns
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Haier Dryer Expert? Answer questions, earn points and help others
