Re: How do I fix my toshiba tablet that wont turn on?
There are certain reasons which does not allow tablet to turn on
Maybe the connecting wire of Tablet and its PCB. I am referring this video, it might help you
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Happened to me. My solution was to fully charge, then hold down power button for like one minute or more continuously. It causes some kind of restart. Last resource, Press Vol Down and hold, then depress power button and hold. This causes it to go back to reset mode. Good Luck.
