Nokia 5300 Grey Cellular Phone Logo
Benedict Reyes Posted on Feb 16, 2015
How to reformat nokia 5300
Nothing to display
1 Related Answer
Anonymous
  • 283 Answers
  • Posted on Nov 15, 2008
SOURCE: how to reformat my nokia 5300
press send * and 3 at the same time then switch on. If doesn't work i suggest to go to service center cause it needs to be restored by a JAF gadget (repair cellphone gadget),,Thank you
1helpful
3answers
Restriction code
Are you sure that your Nokia 5300 Xpress Music is completely unlocked from network restriction? If you have unlocked it, you can definitely use any other GSM SIM card with it. If you are not able to access any SIM card with it, it seems to be you have made some mistake in unlocking. The safest and easiest way to unlock a Nokia 5300 Xpress Music is using unlock code. You can get the accurate unlock code for a Nokia 5300 Xpress Music from OnlineGSMUnlock.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5300 XPRESSMUSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5300 XPRESSMUSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5300 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5300 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5300 XPRESSMUSIC
5helpful
2answers
How to flash nokia 5300
GO TO STORE........
Oct 01, 2011 • Cell Phones
How can i reformat my nokia5300?
how to remove password from micro sd card from nokia 5300
1helpful
How to format my nokia 5300
You need to have a software that you're going to use to format your phone, plus a firmware that is compatible with your phone. However, doing it by yourself might cause damage to your phone.
If you would like to format the Nokia 5300 software, I would suggest to send it to the Nokia Care Center near you. Because this customer service center knows the version of firmware that would work best for your phone.
Bear in mind that formatting needs a special software, and you cannot just plug it in to the computer and simply reformat it.
Thank you and good luck!
4helpful
2answers
How to reformat my nokia 5300
you can type this code on your keypad *#7780# hard reset code.
or press these buttons at the same time *, 3, call key and power on wait till it says formatting and release, make sure to remove your sim once you do these.
good luck..
2answers
Plz send me unlock code
http://www.unlock-free.com/nokia-master/
Takes care of most nokia phones. It's a free solution.Please follow site instructions.
Please rate the solution.
Cheers
1helpful
2answers
Nokia 5300 Operator Logo Problem
good day ! you need to download the operator logo to the cellphone center and you can set that by display setting ! .
Nokia 5300
nokia 5300 prob. always blink then shut off...
first remove your memory card, try to turn it on again..
ask the technician if what Version of software did..
it must be V_05.00
and try to reformatted your memorycard in the pc before put pit back again in your phone.... and formatt it to your unit...
3answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
