A
Anonymous Posted on Feb 16, 2015
I have a JVC ax 220 amplifier and there is no sound coming out at all.
No sound at all.
Audio Service Clinic
Level 3:
  • JVC Master 924 Answers
  • Posted on Mar 23, 2015
JVC Master
Level 3:
Answers
924
Questions
Helped
350884
Points
1710
Is the receiver even turning on? If it is, listening carefully to the top cover, with the room quiet. Do you hear 1 click, or two?
If you're interested in having your JVC repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
4 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Mar 22, 2008
SOURCE: JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Anonymous
  • 2071 Answers
  • Posted on Jul 29, 2008
SOURCE: matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Anonymous
  • Posted on Oct 14, 2009
SOURCE: JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Anonymous
  • 2098 Answers
  • Posted on Jul 04, 2011
SOURCE: I 'm looking for a service manual JVC Amplifier
Just want to clarify the model no if it is a JVC KS-AX3300 Power Amplifier. If yes, how can I send you the copy.
Jdvillanueva
2answers
JVC AX-518V RECEIVER VOLUME CONTROL QVDC94Z-E15FJ5 INTERMITTENT LOSS OF RIGHT SIDE SPEAKERS, THEN TOTAL LOSS. LOOKING FOR A NEW CONTROL.
Please remove all sources of interference from the jvc device (ie radio, microphone, antenna etc). Then listen to the sound again. If the issue persists, please use another power source and check the device cables for any damage.
Thank you.
Jvc ax 444 amplifier
http://uk.jvc-service.net/webtemp/AX-V55.pdf?CFID=15017492&CFTOKEN=79974873
This model is the nearest one I can find, but most amps from the same manufacturer use common parts and circuits.
3helpful
MANUAL JVC AX-90
what is this.....
ðóêîâîäñòâî JVC AX -90
take it to the service center...
Tengo un amplificador de modelo jvc ax-1100bk que cuando lo enciendo me presenta una alerta de protector que problema puede ser por q no tengo el manual de reparacion
Casi por lo regular esa advertencia significa que el circuito amplificador de audio esta en cortocircuito y se necesita remplazarlo si eres tecnico tu lo puedes hacer si no llevalo a un taller de servicio
How do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
3helpful
My JVC AX-33 is giving almos tno sound
My experience tells me that after an amplifier had been used for quite a while (more than 5 years), the contacts (on any button) wear out and become loose. If you try to press to engage, you will notice that the sound will come back on. The most frequently touched/used buttons are the one that wear out easily. These contacts should be replaced with original one. Substitute parts won't last long.
5helpful
3answers
Instruction manual
Trying to use the computer controlled JVC AM/FM Tuner Model FX-333.
I am attempting to use the pre-set stations desired for listening pleasure, but I have not been successful. Can you help me?
The FX-333 Tuner is linked to the AX-R441 Amp.
2helpful
4answers
Hi xaser
regards
Graeme
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
