Computers & Internet Logo
A
Anonymous Posted on Feb 16, 2015
Where can I get the latest 3cblsf26h firmware?
The following firmware have already been tried (and were rejected by the web interface): BL_2226_SWITCH_PLUS_v.1.1.0.15_bfs01.1.0.15 BASELINE_SWITCH_2426_PWR_PLUS_v.1.1.0.15_bfs01.1.0.15
4 Related Answers
Anonymous
  • 121 Answers
  • Posted on Feb 25, 2011
SOURCE: i forgot my admin password
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Anonymous
  • 395 Answers
  • Posted on Aug 01, 2011
SOURCE: in one of my small
That means both switches not communication to each other. They however communicate among themselve. Check uplink port, check cable, may need to use cross over cable for connecting both switches.
When node connecting to switch (3com or cisco), it gets dynamic IP or static, check to see if it obtains IP at all and we go from there.
Thanks
Computer hardware and networking support
  • 4281 Answers
  • Posted on Sep 16, 2011
SOURCE: I have an SF300-24.
Again try with console cable then reset the settings of switch to factory defaults. Run "clear config all" command . Then then you can set ip address for interface vlan 1 ip address. Let me know if you need further assistance. Thanks for using FixYa.
TechyDrood
Justin
  • 2072 Answers
  • Posted on Oct 16, 2011
SOURCE: I would like to find
3Com is owned by HP now.Here is the manualhttp://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02581570/c02581570.pdf
Is there a way to manually update barracuda 300 firmware
Download the latest firmware to your laptop.
Use an Ethernet cable to connect the laptop to one of the "wired" ports on the router.
Connect to the router's web-server interface.
Click into "settings" to find the screen that lets you update the firmware.
Select the downloaded file, and do the update.
Reboot the router.
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
2answers
Wire less disconnect very often When i disconect the wireless and connect again it takes time to reboot the wire less
Disconnecting wireless problems can be cause by any number of things. Please click on this link and follow my instruction to identify the problem and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
My dlink router it worked..but the signal is off and on and off again what di i do
First thing I would do if you haven't already is update to the latest firmware. follow the link below and choose the correct model/revision of the model you own from there you can download the latest firmware as well as the manual if you need it to view how to update the firmware. It is quite easy in the interface when logging into the router. If you need further assistance please let me know. Also please take the time to accept/rate my solution when you find my assistance helpful.
Thank you,
Lee
Kicks me of internet after about 10 minutes. Shows connection but will not let me on browser unless I restart
With regards to your concern, I would advice you to perform a firmware update on your router.
Please verify the exact model number of your unit.
The firmware update should be done on the wired machine.
If your using a netgear router. It will perform an automatic update once you log on to the web interface. To log on to the web interface follow the instructions below
1.open internet browser
2. type in the address bar. http://routerlogin.com
3. Enter username as admin and password is password.
4. Once you log on., it will automatically search for available latest firmware. If the automatic update is not turn on. Just click on Firmware upgrade under Maintenance.
CLick on the button search for updated firmware. Once it found the firmware just proceed with the instructions. IF it didnt find any latest firmware. Visit http://netgear.com and select the model number and verision of your router from the drop down list.
Just click support and you will see a download tab which will show you the list of firmwares. Please choose the latest version.
Running slow
Is it running slow on both wired and wireless connections? how about if a PC is wired directly to the modem? That will eliminate the router as the issue (slow internet could be your modem or the connection itself).
If you're sure it's the router (wireless and wired) then upgrading the firmware would be first step. You can download the latest firmware from linksys.com and get it installed via the web interface of the router (probably found by going to http://192.168.1.1).
If a firmware update doesn't do it you can change your DNS servers from being automatically detected from your ISP to public ones. This may help web pages load faster. You can enter them also using the web interface. Set the Primary and Secondary DNS address to the numbers below (they are from OpenDNS.com).
Primary 208.67.222.222
Secondary 208.67.220.220
3answers
My wireless WNDR3300 router disconnects every few minutes and than reconnects. how do I stop this?
I think you will need to upgrade the firmware of the router.
that will help you.
you will need to download the firmware of the router from the manufacturer's web site then you will need to open the set up interface of the router.and upgrade the firmware.
Click here for more info about how to open the set up interface.
4helpful
2answers
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
Nintendo wii
Follow this link, pick your router from the list and it will walk you through the needed steps. http://www.nintendo.com/consumer/routers/en_na/Belkin/index.jsp This section is just for Belkin routers. You may need to get the latest firmware for router if you don't already have it. To check your version open your router's interface page with your browser. Type 192.168.2.1 When it opens check your version. Then go here. This is for your router for updating the firmware. http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5947&scid=222 Update the firmware first if you don't have the latest version and then proceed to the other link .
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
