Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do I repair the Sony Bravia LCD HDTV?
I am new to the TV repair field and would like to ask a question. My customer has a Sony Bravia 40 inch KDL40V2500. The TV turns on with a green light, then immediately turns off, blinks in red 4 times. It continues to blink in red, until you power off the unit. Is it the power board or the T Con Board? There is no video no sound no signs of POPPED capacitors.
    Scholar:
  • 99 Answers
Hi... If it is a power board problem it is most likely capacitors that fail. Look for any electrolytic capacitors that are bulging on top. They are normally round with an aluminium top with a cross marked in the metal. They fail over time if they are low quality or high ESR with high transient voltages.
Make sure that you replace them with same or higher voltage ratings but with the same capacitance.
If you do buy them for stock in your repair shop look for high quality low ESR variety that will not a cause comebacks.
Hope this helps!
Posted on Feb 16, 2015
6ya staff
SOURCE:
Anonymous
  • 320 Answers
SOURCE: 42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Posted on Oct 19, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
Anonymous
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: my sony bravia 46" doesnt
hi,
you have to replace the inverter board. If the invereter board overloaded the powers supply, then the tv will go to standby after some time.
ok
Posted on Jun 21, 2011
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.
Gillight
Posted on Oct 23, 2012
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Sony bravia 40 inch red blinking light when turned on green light shows but go,s back two blinking red what should i do
you might try washing it.
submerge the tv in the bath tub, use lukewarm water only.
then turn it on.
problem solved.
Sep 13, 2014 | Sony Bravia KDL-40EX700 40" LCD HDTV -...
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia 40
There is an electronic service help site in internet, named "Electro-help'. Google for it. All details about sony blinking codes and cault location method is described in detail. You can get it by yahoo too. Pull up older post there. More than 275 posts, and all of them are related to repair help to electronic devices.
Jun 10, 2012 | Televison & Video
My sony tv lcd screen 40 in. has crack
The cost of a new screen for your TV is not cost effective. And you will need to add labor, if someone does this for you. Sorry. Thanks for asking!
Feb 26, 2011 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
I have a sony bravia 55 inch rear projection tv. model no. KF-55E200A. when i turn it on it flashes green like normal but then starts flashing red. can you tell me what is wrong with it please
Most probably it is an optical block issue. You can contact sony customer service to setup the free service.. If you need the contact infomation, please let me know where you're.
www.fixya.com/users/shajanrs
Jan 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
