HP DesignJet Z2100 InkJet Photo Printer Logo
s
suejohn52 Posted on Feb 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I LEAVE MY Z2100 TURNED ON BUT IT CAME UP WITH MESSAGE TURN POWER OFF AND RESTART. I DID THIS TURNED POWER BACK ON BUT IN THE WINDOW IT STOPS AT 0% WILL NOT LOAD
I HAVE TRIED TURNING ON AND OFF A COUPLE OF TIMES AND IN THE WINDOW IT JUST STOPS AT 0% AND DOES NOT LOAD
Seeker5211
Level 3:
Genius:
  • Master 1,089 Answers
  • Posted on Feb 18, 2015
Seeker5211
Master
Level 3:
Genius:
Answers
1089
Questions
Helped
617571
Points
2611
Pull the power cord and leave it for about 10 minutes. Also unplug the network cable. Power it on and check if any symptoms change.
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
I have a Designjet z2100. I loaded the drivers from the support site. Whenever I print, the printer display reports wrong file format. I am using window 7 64 bit and have tried using windows update to...
Next time include the System error code, in this case 61:XX.
Power off and remove the power cord. Reconnect and power on. Make sure that the correct driver is loaded.
Make sure that the Graphic language setting is correct.
Resend the file to the printer.
Make sure that the Firmware is up to date. Upgrading the Firmware will re-install the PostScript fonts.
It is also possible that the file is password protected.
Do all files fail?
1helpful
Warning. Color sensor may not be working properly. If problem persists call HP.
The listed error message is accompanied by the error code "58:10"
This error code can mean one of two things. Either the color sensor (the spectrophotometer) is malfunctioning - in which the error code would persist and a technician would need to be called. Or the sensor picked up a piece of lint or dust when doing its self-calibration - in which case it would come up as a single occurrence.
Here is a follow-up suggestion if there was any further concern. With the following steps, the spectro instrument (along with the print head) can be inspected. To do that, select "Replace print head" from the front panel and then turn of the power (hard switch on the back of the machine). With the printer off, open the tinted glass and slide the carriage over. This should allow the carriage head with spectro instrument to be brought into view for inspection of an lint or dust, etc. To restart the printer, just close the tinted glass and power the printer back up from the hard switch.
2answers
MY WINDOWS XP INSTALLATION IS WORKING FINE, BUT WHEN I TRY TO REINSTALL IT, MY PC SHUTS DOWN WITHOUT ANY MESSAGE.
go to 1 start button click go to 2 all programs go 3 accessorys 4 in accessorys go down to 5 system tolls in system tools shows a window of more options 6 go to system restore and click on it a window pops out says restore my computer to a ealyer time its checkd 7 click next in the bottom then a callender shows 8 click it on wish date you think your computer was working fine yopu go on the dark blue dates and click or you can even go on top of callender in the sides it shows other months like november or dicember get a date and 9 click next in the bottom your computer will restart if your working on something save work computer will turn restart if it say files saving wait untill it stops in the 10 progress bar the you click endnow the computer will restart wen it turn back dont any keys will it turns on the pc it goes in your desktop icons window shows a screen say restore susesful 11 down the screen click ok and your done if its the same that it was before you can try again this steps please leave a good ratete me thanks
1helpful
Unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
2answers
My computer wont open windows
The short answer....reinstall windows. Yes you well loose what is on your hard drive, but atleast you can use your computer.  Need more help? Let me know. Good Luck!
3answers
"Turn Power Off then on Again" error
Try performing a reset on the device. Unplug the power cable, then hold # and 3 while powering it back up.
14helpful
Printer stops printing half way down page
Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Divide overflow error,
if the start menu click run and enter msconfig
Click on startup and turn off all the programs
Click on Servics and turn on hide all microsoft services
Turn off all other services that are not from microsoft
restart your system
you will see the error has gone
one by one turn back on service and start up programs and restart after ever turn on to isolate which program causes the error
YOu can then leave that turned odd and turn the rest back on.
4helpful
Printhead
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
k24674
Grand Canyon Tech
Grand Canyon Tech
