oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
Are you sure it's your washer or is there an awful sewage gas smell coming up your drain where your washer hose drains in.. I had this happen and I had to instal a U trap in the line the washer drained into.
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
