Question about Coleman Powermate Proforce 2500 Generator
I have gas in oil. Whats the problem ?
Changed oil, new gas, had it running and checked oil and there is gas in it
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
How old is the unit? Gas in the oil indicates sticking or broken piston rings. If it has sat for a long period, best thing to do is spray some sea foam into the cylinder, run it under heavy load for 30 min and hope it seats. If it still does it, chances are your ring is craked. But most often they stick allowing blow by. Also make sure plugs are clean, and not fuel fouled.
Posted on Feb 18, 2015
I have a 2006 Polaris 400. it was running fine then just cut off. Turns over fine but wont fire
Take coil off clean.also remove spark plugs replace or clean and gap.question were you in a lot of water:)
Jul 03, 2016 | ATVs
It will run for a while then cut off john Deere
CHECK GAS FOR WATER THEN CHECK MAKE SURE GETTING GAS CHECK PLUG WHAT DO THEY LOOK LIKE WHEN CUTS OFF DOES IT LOOSE SPARK REPLACE COIL IF DOES 80.00 IF NOT GETTING GAS REBUILD CARB ALSO CHECK FUEL FILTER BAD THING ABOUT TRACTORS IF YOU LEAVE THEM OUT SIDE UNCOVERED THEY WILL GET WATER IN GAS ALL OF THEM SO DRAIN GAS OUT PUT IN NEW ALSO DRAIN CARB OUT ALSO CHECK OIL LEVEL IT HAS A OIL CENSOR ON IT THAT REEDS OIL LEVEL IF OIL LEVEL NOT SAFE THEN WILL SHUT IT OFF TRY THIS LET ME NO WHATS HAPPENS THE RED NECK
Sep 01, 2014 | Garden
Gas is coming from my crankcase on 1997 polaris xplorer 300 whats the problem
if this is the issue, suspect your fuel pump diafram is perished
also check if fuel is getting into your engine oil, check the dipstick and see
if the oil level is hight or its thin and runny oil smelling of gas,
if this is the case, recommend changing the fuel pump and changing the oil, in that order.
I hope this was useful.
Sep 01, 2012 | Polaris ATV
My trimoto 125 mixes gas in the oil whats theproblem
Gas in oil usually gets there in a 4 stroke engine in one of 2 ways- through the induction system from a defective valve in the carburator, or a ruptured diaphragm on a fuel pump that is attached to the crankcase. If the carburetor has a float bowl, the float may be faulty, the needle and seat may be faulty or dirty, otherwise the diaphragm types can have either or both types of valving to control fuel flow into the engine.
Apr 27, 2012 | Motorcycles
K my 460 runs like **** its missing and number one plug was black...i changed wires- plugs -and cap and now runs worse and blowing white and blue smoke....whats wrong with it?
give me more info about your plug, is it black by oil or black powder from gas ?
in the other hand, smoke white is a motor cold on winter, smoke blue is oil inside motor, smoke black is gas not burned,
so be shure exactly what color is...
Aug 20, 2011 | 1988 Ford F 250
I have a 2000 lsi sedan 4cyl runs excellent good compression mileage has got considerably worse down to 22 hwy any ideas
*Oil change.
*Accurate tire pressure. (highway drivers experience better MPG with tire pressure 2-3 pounds higher than whats called for on tires)
*Tune up/spark plugs
*Injectors clearer/replacement. STP injector cleaner
Bad fuel/low grade/gas supplier might be bad. Try new gas station
Mar 30, 2011 | 2000 Chevrolet Metro
Coleman Powermate Proforce 2500 Generator Logo
48 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Tim Garcia
Tim Garcia
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
