HP PL5060N 50 in. Plasma HDTV Logo
s
sheila collins Posted on Feb 18, 2015
The pic will be on and working fine for about 5 to 15 minutes then it will go out of HDMI MODE and the screen will go to a blue screen, it is not staying in cable mode kick it to a different mode.
SERIAL # CNH6460322, WE TRIED SWITCHING THE CABLES and tried using HDMI cable it just wont stay on cable mode and screen goes blue or blank.
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jul 30, 2007
SOURCE: HP Monitor blanking out on full screen mode
Hi, I read this somewhere (can't recall the site). Go to your desktop properties (right click on any clear area of your desktop); Settings tab; Advanced button; Troubleshoot Tab; Uncheck Enable Write combining; Reboot your PC. If this does not fix the problem, you can always revert back. Hope this be of some help. Good luck and kind regards.
sigma_shiva1
SHIVAJI YADAV
  • 188 Answers
  • Posted on May 18, 2008
SOURCE: Not Loading
i m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
regards..
for any quarry u can mail me at-[email protected]
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Nov 06, 2008
SOURCE: My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Anonymous
  • 3 Answers
  • Posted on Feb 12, 2009
SOURCE: hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
skistockli
My2CentsWorth
  • 73 Answers
  • Posted on Jul 11, 2009
SOURCE: Hp TV wont stay on cable setting
contact us for legal action agaist HP for this model HP tv. They sold this TV with known defects. [email protected]
Hello, the DVD play fine but tv mode, continually says no signal and screen is blue. Please help
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
4helpful
3answers
Onkyo TX-SR606 takes up to 30 minutes to display 1080p
Please don't rate me for this. Onkyo has been having voltage problems with their HDMI boards in several models. Yours is one of them. They first instructed techs to replace some capacitors, then add some capaictors to repair the voltage problems. Now they want us to replace the HDMI boards but I have yet to receive any (on back-order) Sorry for the bad news.
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
1helpful
2answers
Hi, I have a 60gig ps3 that works fine on my sony bravia tv, when i try and use it on my LG tv I get a blue screen only, if I load a disc after a minute it then kicks in on the hdmi channel and all works...
have you tried changing the settings on the ps3 for the other tv if not when switching on the ps3 from the consol hold down the on button till it bees the first time you try this the consol will switch off the second time it will go to a settings menue hope this helps
I have an Onkyo TX-SR606. With an HDMI connection from any dvd player connected to the HDMI/DVD in on the Onkyo I get perfect pic and sound initially then the picture starts to go bad, usually about 5 - 10...
Hook your HDMI directly ffrom the DVD to the TV, then connect digital coaxial or optical to your receiver for audio. Your receiver will not current HDMI video codecs. That is the only fix. Sorry. Hope this helps.
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
shaun
Problem switching between 480 and 1080i modes (get blue screen)
make sure that you have the latest software version installed in your tv. You can down load it from the Mitsubishi web site.
4helpful
3answers
Blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
