I have a blank vertical bar that is about an inch wide on the right side of my prints, and it only happens to the black toner. I have replaced the black toner, the entire drum and have cleaned everything I can think of. I have also consulted every manual I could find, and still nothing. Can you help please
SOURCE: Print quality bad
To clear white vertical lines from printed documents follow the steps listed below:
NOTE: The use of non-Brother or generic toner may cause white vertical lines.
Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. First, power OFF the unit for safety. The ON/OFF switch is located on the left, rear side of the unit.
2. Open the scanner cover by pulling the blue lever located below the control panel toward you and lifting the cover. Make sure the cover is completely open.
3. Remove the drum unit by holding each side of the drum by its handles and gently lifting the drum forward (toward) you.
4. Place the drum unit on a drop cloth or large piece of disposablepaper to avoid spilling and scattering the toner. Make sure thedirections and DR-250 stickers are facing you.
5. With the drum removed from the Brother machine, clean the laser glass. The laser glass is located inside the Brother machine where the drum was located. It is a piece of glass, about 1/2 inch wide and approximately 8 inches long, located on the bottom of the inside. Gently wipe the glass with a clean soft DRY cloth. DO NOT use isopropyl alcoholor any liquid to clean the glass.
6. Gently pull up on the mauve lever to turn the toner cartridge toward you until it stops. Remove the toner cartridge from the drum unit by gently sliding it out of the drum unit. ***Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe it off or wash it with cold water.
7. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge. Then, reset the toner into the drum (be sure it clicks into place). Gently push on the mauve lever to turn the toner cartridge away from you until it stops.
8. With the DR-250 sticker facing you turn the drum upside down. There is a blue tab located on the right side. Slide the blue tab back and forth seven times to clean the corona wire. When finished, make sure the blue tab is locked to the right side of the drum.
9. Reset drum unit in Brother machine. Close the cover securely.
Print the help list to test the unit by pressing the REPORTS key located on the control panel and then (1) on the dial pad.
If the white vertical lines still continue, the drum unit will need to
be replaced.
If the purchase date of the original drum or replacement drum is less than 90 days (within the warranty of the drum), contact Brother Customer Service Center at 1-877-Brother (1-877-276-8437) . The center is open Monday-Friday, 9:00am to 7:00 pm EST, excluding holidays.
SOURCE: Vertical black line on all print outs
1) Check the cartridge. Look at the egg color drum and see if there is any built up toner. If there is then wipe off with soft cloth and reinstall.
2) Does this happen when coping from the flat bed and the doc feeder at the top?
If it it's only from the top then there is a glass lense that might have white out on it.
This is common when using white out and not letting it dry long enough.
To get to the lense it my be tricky but if the top of the feeder open a little from the top pop it open and
the glass is a thin 1/4 strip. Wipe it clean then try again. Hope this helps. Boats
SOURCE: Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
SOURCE: My drum is at 40%. I have black vertical streaks
I was going crazy! Had a tech come in and look at the machine - needless to say he did NOTHING! A friend came over and was trying different things. It was that the "rack" that the toner cartridges sit in was not fully seated - once he pushed down a little and heard it "click" I had no more black streaks. AMAZING
SOURCE: black vertical line on prints and copies. 20
It appears that the Teflon is worn off of the roller. You will have to have the FUSER replaced.
