SOURCE: Classixx 6 1200 bosch washer...I've
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
SOURCE: Washing mashine dispalys symbol not in users
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
SOURCE: the water switch to the washer wasnt turn on due
Just unplug the washer and wait a couple of minutes before you plug it back in. That should clear the code and let you get the door open.
Hope you find this Very Helpful and best regards!
SOURCE: My washer is showing a flashing red key with a
Yes.
There
are several reasons that a washing machine won't drain or spin. The
cause could be something as easy as a clog or something difficult that
will need a licensed repairman. Start with the simplest possible cause
and work down to the more difficult causes.
INSTRUCTION BELOW
rate this.
Thanks and good luck.
SOURCE: Key Symbol appearing and cycle
Hold down the start button for 3 seconds. This will unlock the washer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
