Hobart A200 Stand Mixer Logo
l
loring felix Posted on Feb 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Here is a more detailed question of the problem that I have caused myself. I opened up the top of my hobart a200 table top mixer because it was grinding pretty loudly. Ordered the proper grease and packed in in there. The old grease looked pretty good so I left most of it in. Anyway after putting it back together only first gear works. The transmission will shift into second but is real tight going into third. The problem is its not shifting gears,. Regardless of which gear I put it in it continues to run in first. What's the solution?
JoeBarth
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on May 05, 2016
JoeBarth
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
4652
Points
5
Sounds like you over tightened the main shaft nut to much and crushed the brass slip bushings. If they are crushed it will not allow the gears to slip. Only way out is to replace the bushings.
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 18, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255313
Points
4299
For Hobart A200 the capacitor is starting or running capacitor?
It is a Start Capacitor. It give the motor a jolt to get it running.
HOBART, Fits Hobart Brand, For A120/A200, Capacitor ...
Grainger https://www.grainger.com > product > HOBART-Capa...
HOBART Capacitor, Motor Start: Fits Hobart Brand, For A120/A200 ; Item: 235F28 ; Mfr. Model: 00-070487-00025 ; Catalog Page: N/A.
US$41.13
MOTOR STARTING CAPACITOR FOR HOBAR MIXER ...
eBay https://www.ebay.ca > ... > Commercial Mixers
MOTOR STARTING CAPACITOR FOR HOBAR MIXER MODEL A200 REPLACES 7048700018 ; Condition. New ; Quantity. 67 sold. 82 available ; Item Number. 254321066847 ; Brand.
Rating: 5 · ‎ 1 vote
Motor Starting Capacitor Fitting Hobart Mixers A120, A200 ...
National Band Saw Parts https://nbsparts.com > All Products
MOTOR STARTING CAPACITOR FOR HOBAR MIXER MODEL A200 REPLACES 00-070487-00018. 125V, 50/60HZ, 145-174uF. Includes: One Capacitor. Replaces#: 00-070487-00018 ...
US$30.00 · ‎ In stock
https://www.google.com/search?q=Hobart+A200+the+capacitor+is+starting+or+running+capacitor
2helpful
2answers
I have 2 Hobart A200 mixers, and they need to be refurbished. Any idea how much that would cost?
I'd give them a call they would be the best to get a more detailed estamate from.
https://www.hobartcorp.com/locations?s=342
Dc-sm168
Hello, Go here for beaters for your mixer: Hobart Mixer Parts Hobart Mixer A200
Trying to adjust gears on a A200 Hobart Mixer can anyone help?
only adjust ment is top nut tight on center shaft and botton two nuts finger tight then locked against each other. if shifting issue is still a problem you have something inside bad or wrong.
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
2answers
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Grinding
sorry to hear of your misfortune,im a hobart tech and i can tell you right off the bat it would be almost impossible to tell you the solution unless i seen the mixer.be more specific about the noise and where you think its coming from,if its in the transmission i could walk you thru it but it would be a task.first thing to check is that there are no cracks on the mixer.all speeds work?1-2-3.
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
