Stihl HT101 Pole pruner Logo
f
flint brown Posted on Feb 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stihl ht101 blade stalls when slight pressure applied to bade
Brian Manuel
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 189 Answers
  • Posted on Feb 19, 2015
Brian Manuel
Expert
Level 2:
New Friend:
Cheetah:
Answers
189
Questions
0
Helped
48045
Points
490
I'd say you have a fouled plug clean it up and regal it or replace
Stihl ht101 pole saw
The unit was not as advertised. Hard to start, runs poorly and won't idle. Had to take it to the local stihl dealership for service.
For best pole saw open the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
1helpful
Stihl ht 101 spare parts list pdf
Stihl does not supply parts lists to the public. if you want one you will have to talk to a dealer in your area and see if they will be willing to allow you to look at one
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Stihl pole saw trimmer is not pulling gas into the cylinder from the carburetor
could be a carb issue, a split in a fuel line, damaged intake boot or gasket
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Stihl ht101bent pole
Replace bent pole, can cause serious vibration and can be a pain to extend. Send your email and i can send you the illustrated parts list. :)
I CAN'T REMOVE THE SPLINED SHAFT FROM MY STIHL HT101 POLE PRUNER.
Take it to an authorized repair center. Not what you want to hear but its better that way. It is a complicated ordeal that if you aren't trained for you can do damage to the shafts
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
