If the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
SOURCE: how to put the rival soft serve ice cream maker back together after cleaning it
see how much appreciation there is for helping some people? Havent even got the courtesy to provide a rating or a thank you for the effort to help them!
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
SOURCE: need to know how to clean the taylor soft serve
http://www.taylor-company.com/
go to this web site and just click on operators manuals. Then either enter your model number or you can use the drop down menu.
SOURCE: taylor soft serve ice cream machine model #y754-27
If you need parts go to softserveparts.com tell them shaun sent you.
