I lost the directions, need instructions to set timer
Http://waterheatertimer.org/How-to-set-timers.html
Link above has step by step for mechanical timers
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
SOURCE: Brinks model 44-1050 digital outlet timer- I don't
I have an instruction for a Brinks 44-1030 which I believe programs the same. If you email me at [email protected] I will send you a PDF scan of the instruction.
SOURCE: I need instructions for how
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
SOURCE: BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15-
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
SOURCE: I have a brinks 44-1030
Manual is shown on links below:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
