If you are trying to use someone else's WiFi connection.. example you are at the airport and the device can't find a network connection.. it means that where you are in that area.. the network connection is too weak to be useful to your device or that the server's router is on but not able to stream any data to you.
if it is at your home, it means that you may need to allow WiFi access to your device. you may need to change the channel of the router, or try just power it off for a few minutes and then power it back on to reset it. It could be that your router is not syncing correctly with your ISP. Call your service provider and see if it can be fixed on their side first. If not, they can work with you to step by step eliminate what it might or might not be.
