Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Hi! Turn on TV and press the TV button by aiming it to TV, the red LED light will blink once. Press the MUTE/SEARCH button. The LED will shut off first then light up. When the TV turns off, press the OK button to store this code.
Please do rate this solution as FixYa and revert for further assistance.
I just got the same remote to work. I did the auto scan method in the instructions. turn on the tv, hold the tv and power button on the remote down until it stays lit. Then press the play button, the remote will blink 10 times, press play again and the tv should turn off in a few blinks. then when the remote finishes blinking, press the reverse button until the tv turns on again, when the tv turns on, press the stop button. Hope this helps!
Please follow the steps below to program your remote control to equipment other then your DISH receiver: Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control. 1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. 2. Press the numbers 5-0-0 on the remote control. 3. Press the Pound (#) button on the remote. 4. Press and hold the correct Mode button until all mode button backlights illuminate, then release. 5. Press and release the Power button on the remote control. 6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. 7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. 8. To verify the code works try several different functions for that equipment. Let me know if this helps and please rate this solution. lone99star
The power supply most likely failed on your TV.
I service these power supplies.
Let me know if you need further assistance. my email is [email protected]
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
