Question about Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh...
My older model of Frigidaire refrigerator will not stop running. we cleaned dust and stuff out of the back, but won't shut off. Whats wrong with it?
We cleaned out the back but fridge still keeps running. We don't know whats causing it. Maybe a thermostat?
To check the thermostat, just remove one of the wires from it, if it then stops, but keeps going and does not shut off when you reconnect it, the t/stat is bad.
Posted on Feb 21, 2015
6ya staff
SOURCE:
Refrigerator keeps running won't shut off
You might try pulling it out from the wall, taking off the cover on the back at the bottom and cleaning it out. It's probably filthy (from dust and stuff -- most people's get that way). If that doesn't fix it, check your thermostat in the freezer section. Turn it down a bit. If that's still not it, you may need to call a repairman (or woman!).
Jan 14, 2013 | Magic Chef Refrigerators
Water leak
Whats the exact model number?
Apr 28, 2008 | Refrigerators
Frt21nnh freezer won't freeze, no frost build up... cleaned dust and hair from back periodically. can you help?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 20, 2011 | Frigidaire FRT18FS6C Top Freezer...
My refrigerator won't cool but the freezer seems to be still working. What can I do to fix it?
Hi. Try this:
1. check the bottom of your fridge, there is an air intake grill at the bottom, make sure this is clean and free of lint/ dust
2. make sure the thermostat inside is set properly
3. don't overload the freezer section. the cold air for the fridge comes from the freezer, and if you have too much stuff in the freezer, it will stop the air from being able to flow to the refrigerator section
4. Finally, if you're a little bit technically capable, check the back of the refrigerator, for a small 1/8" hose going down the back of it- make sure this line is clear and free of gunk
Jun 05, 2011 | Frigidaire Refrigerators
I have a new Frigidaire whirlpool 3 month old . stop cooling and makes a lot of ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Frigidaire FRS26R4A Side by Side...
I have a Frigidaire FRT04GM fridge. The Fridge stopped working. I looked in the back and found what appears to be a timer with a small opening for a screwdriver. I reset the Timer and it worked for about...
I think you are thinking correctly...:-)
heatman101
Sep 21, 2010 | Frigidaire Refrigerators
Fridge completely stopped working. This happened a couple of weeks ago but after cleaning the dust off the coil, it worked again. However, this morning it went out again. Please help.
If you can tell me what model and make I can solve this for you, for example Frigidaire, GE, Whirlpool, Sears Brand that has different numbers like 159.58975
Let me if this is a GE brand and model number, Thanks, Sea Breeze
5a66864.jpg Here are my site hyperlinks below.
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 16, 2009 | GE Refrigerators
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Top freezer won't stop running
  • it sounds like the compressor is getting weak, taking more time to build up pressure.
  • keep an eye on the temperature (with a thermometer)
  • i would start shopping for a new refrigerator ASAP.
Jun 29, 2008 | Whirlpool Refrigerators
Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh... Logo
100 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
