E20 error code is the drain system, either an obstruction in the hoses or the motor doest have enough power ?
motor as in the water pump or ?
more in likely it just an obstruction in the hoses or build up at the motor pump unit, the first thing a service tech would do is take it apart , check everything, and clean everything, reassemble. debris builds up over time on the system causing it to not preform efficiently
ok ill pull it apart an check
Seems to be a common issue with Simpson. My is doing the exact same. Same model as well.
I find if I blow down the pipes it clears as I have already pulled it apart and found nothing wrong. No blockage.
SOURCE: my aeg washer dryer comes up with e20 flashing
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
SOURCE: I have a 3 yr
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
