Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream Sandwich Multi-Touch Screen Tablet Logo
A
Anonymous Posted on Feb 22, 2015
Adapter in tablet won't charge - Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream Sandwich Multi-Touch Screen Tablet
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
1helpful
I cannot get the tablet to charge. I am trying using the USB port, as I cannot be sure the a/c adapter I have is correct. Thanks
If your not getting any indication lights on tablet could be wrong USB adapter transformer. It could also be a bad wire from adapter.
You did not indicate type of tablet or adapter you are using. Worst case you have a bad battery in table and would most likely ha e to be sent in for repair. However if you have a cell phone USB charger for a car try plunging in tablet in and see if it charges. If it does get a new adapter with higher amp than the one your using. But beware the batteries can only be charged to a max amp see web site for you tablet for recomindation.
1helpful
My tablet is not charging
Does the tablet power on when plugged in?
Have you tried a different power outlet, or a different power adapter?
Does the connector on the tablet seem loose or will the tablet charge if you hold the charging cable firmly to the charging socket?
Depending on your answers, it could be a bad charging port on the device, or a bad power adapter/cable, or a problem with electrical outlets. The remaining option would be a battery problem.
I post on behalf of HP.
1helpful
It won t charge since the snow storm last Thursday the battery wont stay on
Does it use an AC adapter or a USB cable to charge? The AC adapter or the USB cable could be bad. Try another cable/adapter. Does the tablet show a lightning bolt on the battery icon when you connect the charger or nothing at all? Does the tablet power up when you are connected to a power source? If the answer to both of these questions is yes, then it is probably a bad battery or charging jack. If the tablet is under warranty, contact the store where you bought it or the manufacturer. If it is not under warranty, try an independent cell phone store that might be able to open it for you and see what type of battery you need to replace it. Get the battery pack model number, size, voltage and maH rating and search for a similar battery on Ebay.
2answers
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
2answers
2answers
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
2helpful
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Top Shopnbc Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
