Washing Machines Logo
A
Anonymous Posted on Feb 22, 2015
Hoover washer e23 code? thanks - Hoover Washing Machines
1 Related Answer
Anonymous
  • 1531 Answers
  • Posted on May 19, 2010
SOURCE: E23 error code
this is a drain pump relay on the control board failure.you either need to replace the wire or the main control board
How do I find the control panel that controls the pump motor? Due to error code E23?
Frigidaire GLTF2940FS1 washer Error Code E23 ...
www.shopyourway.com > Manage My Life > Questions
Sep 13, 2013 - My washer stopped mid-cycle and emitted a burnt odor. Troubleshooting shows error code 23. I pulled the connector off the pump and have ...
Kenmore Washer (48112) E23 error code ' ShopYourWay
Get shopping advice from experts, friends and the community! Hey all, I have a Kenmore front load washer model #48112. When I hit the start button the NO ...
Error code E 23 How do I test drain pump? The unit rolls to the left then shuts off with a beep beep beep.
[PDF]Error Code E23 Frigidaire Washing Machine - WordPress.com
https://grednandwestsign.files.wordpress.com/.../error-code-e23-frigidair...
E23 Drain pump relay on control board failed or wire off pump. E24 Drain pump relay If your. Frigidaire Washing Machine Error Code is not listed here, check Then the code E41 appeared and. I could do nothing else with the washer. The error .
I have an Affinity washing machine that shows an E23 error code.
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
What does error code E23 on a frigidaire affinty front load washing machine mean
Good Morning Friend,
I understand you are receiving an E23 code on your Frigidaire Affinity washer, model# GLTF2940ES. The E23 code states that the drain pump relay on the control board has failed. This could also be a possible false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
My frigidaire afinity washer was not draining. I opened up the washer and there was a small sock in the drain. i removed it and started the washer again, but the washer still will not drain. it gives me a...
Hello Juan, thank you for your post!
If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board possibly needs replacing. One of the best ways to determine if this is a false error code is to reset the power to your Frigidaire washer by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z.
Code E23 comes up om my Frigidaire Affinity front load washer. I have changed the motor control board but still have the code E23, checked the wiring harness and everything looks good. Unplugged the pump...
Hi James, thank you for your post! If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. However, since you have already replace the control board, one of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker. It is important to wait roughly ten minutes and then turn the washer on. If the error code persists, it would be advisable to reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
E23 error code
Kenmore 44082 front washer will not drain or fill
e23 is not a valid code.
Please re-check and post if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
