Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Fix buzzing noise on my Sony bravia tv
Buzzing noise comes and goes as the picture changes
6ya staff
SOURCE:
Anonymous
  • 334 Answers
SOURCE: buzzing noise from rear of 26inch sony flat screen
cheak back light settings turn it all way up if down to low it will buzz in video options
Posted on Oct 15, 2008
Anonymous
SOURCE: tv is buzzing when in use
There is a PC board in the back that will have transformers on it ,if you know how to solder you can probaly fix this yourself, find the one that is humming unplug the tv and remove the board with the transformer,remove the transformer from the board and soak it in some lacqer for a day ,tap it a few times to be sure it gets all in it,let dry for a couple of days and replace this should stop the buzz if not sure how to do this ,let a qalufied tech preform this for you ,knowing the problem might save you some cash
Posted on Jan 19, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Posted on Oct 23, 2009
Testimonial: "Thank you very much for the very prompt reply. This seems a very likely cause. My TV is only a week old so I will contact the supplier. Thanks again."
paulus678
SOURCE: hi i have a Sony Bravia KDL37EX403U 37'' Freeview
This is a common problem with this screen, and is caused by a faulty inverter on the panel. Newer ones have a modified part and the fault is recognised by Sony as a manufacturing fault. Therefore you should have no problem having it repaired.
Posted on Jan 19, 2011
Sound comes and goes constantly on a sony tv model KP60XBR800
About 27,600,000 results (1.16 seconds) Search Results
    Sony TV sound issues - Forums - CNET
    www.cnet.com > Forums > Sony
    CNETJun 11, 2015 - I have a Sony Bravia KDL52V5100 LCD TV & after only having since May 2009, I am now having sound ... I'm going to purchase a new HDMI cable to see if that might solve the sound cutting out problem. ... Has anybody come across problems like these 2? .... Sony is and always has been one of the best TV's on the market. Netflix app on Samsung Smart TV audio dropping out
    Jun 11, 2015
    sony bravia automatically turning off and on
    Jul 7, 2012
    Clicking noise after powering off sony kdl-40v3000 lcd hdtv ...
    Oct 25, 2007
    More results from www.cnet.com
    A loud humming or buzzing noise is coming from ... - SONY
Jan 05, 2016 | Sony Televison & Video
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Buzzing noise from TV when playing DVD/Photos
Usually this noise is the result of a bad cable. Unplug to see if noise goes away. If so, try different cables.Has solved that problem for me several times over the years.
Dec 19, 2017 | Sony BDP-BX2 Blu-Ray Player
Buzzing/fizzing noise from back of sony flat screen tv
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia LCD T.V.
It is most likely a fan (there are 2 to 3 of them in the set) that is making the noise. I doubt seriously that the lamp is causing a buzzing noise. The only other buzzing sound can come from the ballast wich powers the lamp.
Nov 28, 2007 | Televison & Video
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
