Not sure how to set the signals (beep,shock strength etc.)
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
