Question about Kyocera Km-3035 Copier, Print,scan,fax , Fin mfp
My kyocera 3035 print out nothing but black paper. what's hapng??
When i copied something, the result paper is fully black with no space even if the source is blank paper.
    New Friend:
  • 45 Answers
Nesesitas give more information, but the problem is in the main charge corona,
replaces the charging wire crown,
Posted on Mar 03, 2015
2 Suggested Answers
6ya staff
SOURCE:
l_j_duplessi
Louis Du Plessis
  • 29 Answers
SOURCE: Kyocera 3035
if ti is a print from machine memory and not from glass the charge is durty the remove charge unit aboth drum and see if there is not durt on the charge wire or on the grid wires the green charge cleaner aboth the wast toner may also have come of and now staning on the rong place , if that is right your laser **** glass behide the drum may be durty if its a copy the small glass onther the document feeder is durty some copiers have a document feederthat have a scanner on the inside oppen the feeder lift the green lever and you fined a small glassin there that need cleaning and last o yes and last do this first open your left side door look at the drum if there a line on the same place than on the paper the drum blade does not clean it and a peace of paper may be stuck betweenblade and drum
Posted on Aug 07, 2012
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
When copying a book there are black inks in border
If you copy something that is smaller than the paper you are printing on, this will happen, especially with a book. The copier will copy everything within the sensor range, and if there are no area to copy, it will scan in the blank space. With a book, the cover will be elevated, and the sensor will pick up the "black" border you are talking about and copy it to the paper.
Feb 02, 2010 | Samsung SCX-4300 Monochrome Laser...
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
MP 780 DOESN'T PRINT
Try printing something in a colored font, like red or green and see what happens. This printer uses two black ink cartridges. It uses the larger one for black text printing. If it is dry, blocked, or damaged, your text (usually black) will not print. Changing to a color font will rule that out.
Good luck.
Feb 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
BLACK INK COPY FUNCTION
Something is definately damaged and with the low cost of printers and the high cost of repair I would recommend just replacing it. Hope you find this helpful,
George
I'm also disabled with a broken neck :-(
Jul 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not photocopying
Open side, look at black assembly on the door, there is either a black spongy roller there or two wires in a black assembly,
1- wires may be broken resulting in blank copies
2- roller out of place
3- HVT (high voltage transformer) not working
Jun 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Kyocera Km-3035 Copier, Print,scan,fax , Fin mfp Logo
215 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
