Xerox Workcentre 5325/p 5325 Mono Advanced Multifunction Copier/printer/scanner Logo
A
Anonymous Posted on Feb 24, 2015
MACHINE MODEL XEROX 5330 DISPLAY SHOW ERROR CODE 042-323
docukaaf
Level 1:
Habit-Forming:
  • Contributor 38 Answers
  • Posted on Jan 31, 2018
docukaaf
Contributor
Level 1:
Habit-Forming:
Answers
38
Questions
0
Helped
48138
Points
50
The drum motor is not rotating due a xerographic module damage or fuser module. Check all is not tighted
kinley
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2018
kinley
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4424
Points
15
How to solves the problems
S J Parkin
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Apr 21, 2017
S J Parkin
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
35329
Points
168
This is a black drum motor drive failure.
  • kinley
    kinley Jan 30, 2018
    whats the solutions
  • Edifice Technologies
    Edifice Technologies May 17, 2018
    I replaced the drum unite but issue still coming
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Jan 02, 2008
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
impressmedia
  • Posted on Dec 01, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Anonymous
  • Posted on Jun 10, 2009
SOURCE: Xerox DC12 Error code 9-355
mi da errore 3- 355 cosa devo fare?
redzventures
Jay Otaigbe
  • 149 Answers
  • Posted on Jul 31, 2009
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
elmojado
YOUTUBE-CLOUDYDREAMS
  • 110 Answers
  • Posted on Nov 05, 2009
SOURCE: How do I access the diagnostic menu for the Xerox
You can access the diagnostic menu by holding the back arrow key and the "i" information key. What you do is press them before the machine is turned on. you can let them go after saying entering diagnostic menu.
Testimonial: "Very helpful...but now printer is asking for a password?"
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
2helpful
2answers
Xerox WC 5330 error Code 010 338
Hi
Iam KISHORE
Xerox 5335 error code 10-338 plaze slow tellme tha problem
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
I install xerox wc 5330 new machine when turn on gives error code 123- 333
The error is a communication error between the main board and the User Interface Board. Check the cable and reseat.
Error code 116 330 workcentre 5330. already several times tried power ON OFF. but still same error is coming...
This code is HDD fail. You may be able to reformat by holding down stop, start and 4 keys and turning on power. failing this try stop,start and 6
Xerox 5325 fault code 124-374
this error is mismatch serial no
go to dignostic mode go to adjusment other re input serial number
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
How to fix fault 116-365 of wc 5330
Solutions for : Fault Code 116-365: An Internal Shutdown Occurred After an SPL Processing Error Related Fault Code: 116-365 Solutions ranked by relevance:
  1. Delete All Jobs From the Job Queue
  2. WorkCentre 5325/5330/5335: Power the Printer Off and On
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
