The use-and-care manual says that the 'product will eventually fail,' and to install a drain catch pan.
The product has stainless steel tank with 3 year warranty. 1-800-558-5700.
The manual does not show parts diagram, element, or anode rod. This indicates that operation is inside a sealed 1-piece unit not meant for repairs.
High clorine content of water, and hard water, and water pressure over 80 psi will adversely affect any tank heater, and shorten lifespan causing probable leak.
Turn off power:
If you can remove cover from H770, then inspect 750 watt element for possible leaking. Then replace with new element of unknown type if element is leaking.
If leaking is coming from the tank itself, then the unit cannot be repaired. This is true for all tank water heaters.
http://waterheatertimer.org/Leaking-water-heater.htmlhttp://waterheatertimer.org/How-to-install-under-counter-water-heater.html If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
