Electrical Supplies Logo
A
Anonymous Posted on Feb 25, 2015
I need a wiring diagram for a generac 6551 model
Model 6551 generac gen set wiring diagram sent to me
Nottz
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Mar 02, 2015
 Nottz
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
40169
Points
88
Please provide the serial number of the unit and what diagram you are looking for as there are many. I will email you the diagram
I need the wiring diagram for 67680 avr generac, where togo the exiter wiress ans sensing wires
Unfortunately, Generac does not provide wiring diagrams for their products. You will need to contact a local Generac dealer or service center for assistance.
Wiring diagram for generac 4702-0
Contact Generac directly to request the diagram.
1helpful
Need Users manual for Generac 4000 EXL generator
Hi and welcome to FixYa, I am Kelly
Below is a list of all the manuals an owner should have:
For the 4000 EXL Your actual model number is 01645.
Operators manual:
http://www.generac-portables.com/document/index.cfm?doc=1645_0EN11CS_LO.pdf
Wiring Diagram:
http://www.generac-portables.com/document/index.cfm?doc=1645_0WDS_LO.pdf
Parts List:
http://www.generac-portables.com/document/index.cfm?doc=1645_0PARTSLISTCCS_LO.pdf
Thanks for choosing FixYa,
Kelly
May 18, 2011 • Garden
2answers
I have a 10 KW Generac Guardian Stand By withe a prwired EZ transfer swithc. Everything works except the 12 volts battery charger. What could be the problem. Only have three weeks innstalled.
Your generator is equipped with a battery trickle
charger that is active when your unit is set up for
automatic operation. The trickle charger is
designed to help extend the life of your battery by
maintaining the battery when the unit is
not running.
you will need to review which circuit bord controls this and have that board replaced or serviced some of these gen heads have this built in and it will be the rectifier in the gen it self it will be a black 1x1x3/8 inch with a mounting hole in the center and 4 lug post for the wires replace this and your issue should be solved but consult your dealer for witch unit you have as to a control board external or the built in rectifier hope this helps.
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
