I need to REPLACE THE ELECTRIC CORD IT DOESN'T HAVE ONE, I DON'T KNOW WHERE IT IS ON THE BACK OF THE WASHER
SOURCE: Maytag neptune TL model #FAV6800AWW
The error code nf is supposed to mean that NO water is coming in. Sounds to me like the water is coming in but the water level pressure sensor tube is either kinked or broken or the sensor itself is faulty. Before doing anything else you should disconnect the tube and blow it out - see if there is a tear or pinhole in it. If the tube is o.k. then you probably need a new sensor. In either case, I would really like to hear from you directly by Email at [email protected] .
SOURCE: Maytag Neptune TL FAV6800AWW Overflows
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump.
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
SOURCE: "od" alarm on neptune tl
Hey geonkarla637,
Good job on troubleshooting, let’s focus on the Left Hand Lid Lock. It has the dual signaling functions to allow the Machine to operate as designed. The first signaling function is “Lid is Open/Lid Closed” signaling the “OP” error code for lid is OPEN if you press the Start button at the Start of a cycle or during a pause and resume portion of a cycle and “OD” error code if the machine has not seen the lid open for three completed machine cycles your issue. The second signaling function is “Failed to Lock” the “FL” error code.
Because the Control Board programming is looking for the contact open/closure transitions at appropriate times of the wash cycle from the Magnetic Reed Relay in the left lid lock. I see no way to fool it by bypassing the magnetic reed relay in the Left Hand Lid lock assembly and have the machine work as designed.
What I would do next is remove the Left Lid Lock and very carefully open it up. I found it is very easy to break off the enclosure locking tabs. I use a fine flat jewelers screw driver and X-acto blade and work around the locking tabs to open the case halves. I wedge small paper clip ends in the case halves as I work around the tabs. Again I stress they break off in a heartbeat take it slow and no coffee for 24hrs before you begin this operation …. (:
How do the black and red wire on the reed relay look? If they look like this I would take a low wattage soldering iron fine pencile tip 25W no more than 60W iron and solder back on the broken end if that has happened. If you don’t want to deal with that you need to replace the Left Hand Lid Lock .
I would also use a drop or two of WD-40 on the slide switch in that signals “Lid Is Locked”. I’m going to include a pic of my attempt to document the Left Hand Lid Lock Control Board inputs and signaling outputs. I have labeled the Pins on that lock assembly for my reference, I cannot correlate them one for one to the schematic packed in the machine console. I have measured and watched the +12VDC input and output transitions with my DVM for the Lid Is Closed and Lid is Locked on the Control Board at connector P3. If your Left Hand Lid Lock is signaling correctly out of the assembly then I would trace the +12VDC signaling back to the control board. From your previous troubleshooting you have insured there is no corrosion on the male Left Hand Lid Lock assembly and the mating plug end.
Please let me know what you find, I hope this helps; I’m a rookie owner still learning how to troubleshoot/repair the machine.
As a side note I unplugged the Right Hand Lid Lock and taped up the plug end. I would never replace that lid lock if it failed my choice; I find it helps to simplify troubleshooting.
Good Luck …………..Rich
SOURCE: Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;"" FAV6800A/FAV9800A Outer Tub bearing replacement""
don't visit this site very often and I don't want to troubleshoot FAV6800A or FAV9800A issues here.
I have two DIY sites that I try to provide owners support as a knowledgeable owner.
You problem is related to a Clutch Issue. Google these keywords ""[FIXED] Maytag neptune FAV6800aww wont spin""
It's a long post it was difficult for me to pull accurate info from the owner for the issue. Fo him the Upper One-Way bearing on his machine was seized. All of these machines are ready after 6 years + of operation are ready for a Outer Tub rebuild. It's a few hundred dollars to do if you have to replace the Clutch Pulley as part of the process.
But one step at a time read the thread [FIXED] Maytag neptune FAV6800aww wont spin and see if this is a DIY project for you. It
disassembly.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
