Question about Samsung LN46D630 46 inch LCD 630 Series TV
Green vertical lines & screeching noise - Samsung LN46D630 46 inch LCD 630 Series TV
    Top Expert:
  • Samsung Master
  • 76,173 Answers
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Posted on Feb 26, 2015
6ya staff
SOURCE:
When powering on a samsung tv LN37A550O3F TV I get a green screen with lines and screeching noise. What is the cause?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 13, 2017 | Samsung Televison & Video
I have Samsung 58" Plasma model Pn58a550s1f that turns on and off with green lines and makes loud noises. Eventually fixes itself.
Oct 06, 2016 | Samsung Televison & Video
Why has my television screen got a green vertical line on it?
Jul 27, 2016 | Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Samsung TV started Green Vertical Lines screeching sound tv turns off and cable box resets up to 15 minutes before clear picture and sound work.
Jan 20, 2015 | Samsung Televison & Video
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Green/blue vertical lines, no pix, screeching
This is a cap problem too.There is a third 1000 microfarad cap near the other 2 I would suggest you replace while you are in there.The instructions are very good and if you follow them carefully it should be an easy repair.If you have a friend who does some electronics and are unsure of your ability it will be duck soup for anyone who can solder.
Aug 22, 2008 | Polaroid FLM-3732 Television
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
SCREECHING AUDIO
My Vizio (don't know model # off hand, 32" bought at WalMart in Jan), is doing the same thing. It did it once the day I set it up; thinking it was just a glitch or something about my lack of knowledge with HDTVs, I powered it off (the hard way, yanking the power cord, as it won't turn off any other way) and restarted it, everything seemed OK. It did it again around April, same thing, just a glitch I figured. I changed some cables, attached more devices, and it has been doing it about twice a week now.
Sometimes it is the full video lockup, with vertical green lines, and full blast audio screech. A couple times it has only partially locked up the video (green vert lines, but still some movement), and no audio screech. Did it last night most recently, hence my google search.
Anyway, my point is, this is probably more common than we were both thinking, and they know just from your description what the problem is. I would try to have them repair such a known-issue free of charge, even out of warranty.
Jul 19, 2008 | Vizio L32 32 in. LCD HDTV
Samsung LN46D630 46 inch LCD 630 Series TV Logo
129 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
