Question about Samsung UN32D4000 UN32D4000NDXZA 32 inches LED-LCD TV LCD Moni
My Samsung LED has a flashing blinking light on the front. When I power on, it does not go into standby mode. It just turns solid red for a few seconds and then starts blinking. No image on screen. Is it my main board or my power supply? Thanks
    New Friend:
I'm guessing you meant to say 'power off''. Otherwise it sounds like you have reasonably guessed there may be an electronic malfunction -- but with this, as with any device with a 'chip', I'd suggest first literally 'pulling the plug,' or if it's surge protected powering that down. Give it 30 seconds or so, then power back up. Best of luck!
Posted on Mar 01, 2015
6ya staff
SOURCE:
My 55" plasma Samsung tv model number PN51E450A1FXZA. The red power standby light is lite but when you hit the power button it blinks and returns to a solid red with no picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 06, 2015 | Samsung Electronics Samsung 51" E450...
Led lite blue solid and led lite red solid when i turn on my pdp-5070pu
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | Pioneer Televison & Video
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Runco Televison & Video
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Sony Televison & Video
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
continue f
Jul 08, 2011 | Sony Televison & Video
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Samsung UN32D4000 UN32D4000NDXZA 32 inches LED-LCD TV LCD Moni Logo
1,018 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
