Most panels are held in place with clips attached to the underside of the panel. There may be screws as well attached to any handles used to lower the gate. If all screws are removed, pull on panel and the clips will release
Replace the gate latch. Open the gate, remove the top panel first, it pops off. Remove the bottom, 2 to 4 screws to remove, then it pops off. This gives you access to remove the latch.
Hi, this is a popular Skyrim quest bug and I'm not sure if its been adressed on the PS3. But If you have a game saved before this point in the Arniel's Endeavour quest, checkout this link:
You should be able to remove the trimpanel on the lift-gate. then at the location of the striker in the middle-bottom of lift-gate you should be able to access a rod. Grab the rod with pliers, if pliers won,t fit the rod connects to a metal lever attached to the striker assembly, pry the lever away from the striker and this should release you gate....Good Luck!!!
