Epson Stylus C86 InkJet Printer Logo
M
MARTIN Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I FIX EPSON C8600 E520 ERROR?
PRINTER SAYS E520 AND WONT DO ANYTHING ELSE
Jay Plesset
Level 3:
  • Epson Master 2,942 Answers
  • Posted on Jun 15, 2015
Jay Plesset
Epson Master
Level 3:
Answers
2942
Questions
Helped
667811
Points
9879
This site:
Thread Epson Aculaser C8600 Service Req E520
says, "If you're not a technician, I'd suggest doing what the error says and calling a qualified service organization."
3 Related Answers
bzet1820
  • 700 Answers
  • Posted on Aug 02, 2010
SOURCE: epson aculaser c8600 error message E833
my codebook said that in this particular printer service request e833 point to mis-assy ...
i do not know where are you located but in germany this bit cost over 300euro... bit can be exchanged on site by yourself, it is front part of the side feeder assy...
if you find my answer helpful, please do not hesitate to vote4 for me, thanx!
divalmeida
  • 3 Answers
  • Posted on Aug 19, 2011
SOURCE: Epson aculaser c8600 error message
I had a problem with the manual tray once. I don't remember the error number, if it was the E833, but the tray didn't lift up at the time. I solved the problem myself just disassembling the tray motor, on the right side. I realized that one plastic gear was a little cracked, so it lost strength to wheel. I didn't purchase a new motor, I simply reinforced the gears with a special kind of glue. Guess what, it worked!
drvalentine
  • 876 Answers
  • Posted on Feb 26, 2015
SOURCE: EPSON E520
E520 is an error of the 2nd BTR (2nd rollers of transfer)
How to fix Epson L210 Printer with these errors: -2 Red lights blinks together -No error appears on screen -It prints for few pages but the error on the printer gets back again ang again Please
Epson printer blinks both red and green lights, which means the paper gets jammed in your Epson printer. You can fix the issue using the steps:
EPSON Aculaser C8600 prints a page on two separate sheets and jams (usually after 8 pages printed correctly).
Check the paper. Before inserting paper separate it from on another so that they wont stick together. Sometimes printer would take two papers at the same tome if the papers are sticky to each other and and can cause jams.
if you wish to have more details check the link bellow
http://electro-medical.blogspot.com/
EPSON E520
Epson aculaser c8600 error message E833 epson...
2helpful
I have an error according with my printer EPSON ACULASER C8600 { CODE E510 }
This error code refers that your motor is not functioning properly. You better go for servicing or support from the service center. For more error codes and causes, you can check out this link below http://www.theprinternetwork.com/printthread.cfm?Forum=116&Topic=1275
6helpful
2answers
Error service req E511, all lights flashing
Possible parts that caused the error
1 Photoconductor Unit 2 SENSOR TR-0
3 HARNESS-ASSY XERO 4 MOTOR ASSY P/R
5 HARNESS ASSY MAIN 6 PWBA MCU
7 LV/HVPS
16helpful
Error e520
E520 is a 2nd BTR sensor error. It is usually caused by waste toner getting on the sensor. Turn off the printer and open the top panel. Lift up the orange handle to unlock the PCU and remove the PCU by lifting it up using the carry handle. Be careful with the PCU drum as it is easily scratched and avoid bright light. Inside the printer on the rear "wall" is a spring loaded cover which can be pushed down to uncover the sensor. It will stick in the down position, do NOT try to force it up again (it will spring back into the right position when the PCU is refitted). Give the sensor a wipe with a soft cloth and refit the PCU. Close the lid and turn back on, with luck all will now be well. If you still have the same error it is time to get proffessional help unless you are experienced at testing voltages and taking printers apart.
Hope this helps, please take a moment to rate this solution.
Epson stylus photo rx 510 - turn on, wont do anything says error then scrolls scanner error
i have a epson stylus photo RX510 wont install into my computer with out the cd any ideas how to fix this
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
