RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet Android 4.1, LCD Touchscreen, 800x480, 4 Hours Logo
A
Anonymous Posted on Feb 26, 2015
How Would I know if my tablet was broken?
It won't turn on.I have been pushing the on button but,it still won't turn on.
Selina Broklyn
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 02, 2015
Selina Broklyn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
249
Points
Hi not op.. but searching for help. Battery @ 100% and touch screen buttons not recognizing touch... This tablet belongs to my disabled 7 yr. old HELP
I have a Samsung Galaxy 7.0 plus table and my power button is broken and so is the up and down volume button and I cant get my tablet on is there any other way I can get it on
Behind the plastic power button is a tiny metal switch. If just the button is broken, use a tiny plastic tool to push the switch. But if the switch is also broken, I recommend returning the tablet for a refund or replacement if it is still covered by the factory warranty.
Fixing a broken power switch is delicate work and may cost more than the value of the tablet.
My tablet won't turn on
Atonio, Check the attached troubleshooting links for tablets not turning on,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Do When Your Android Phone or Tablet Wont Turn On
Help My tablet won turn on what do do
my android tablet wont turn on how to fix
Why Does My Android Phone or Tablet Not Turn On
What happens when my tablet won't even turn on?
Hi Mike, The link below is a youtube video showing you how to fix your tablet....CHEERS..
How To fix any Android Phone Tablet that won turn on
2answers
Why does my tablet need to be plugged in to turn on.
Two things, 1) The battery is finished.
2) On/off switch is broken.
Good Luck,
dean.
My tablet wont turn on
I know this is a long shot, but if the button is stuck it usually is broken. IPhones of all generation are notorious for this, usually if you just plug it in the screen should light up. You than should be able to open and access your files. I would turn off the automatic lock in the tablet settings.
Power button is broken need alternative way to turn on tablet
What type of tablet? In order to turn on the tablet, the circuit board needs to see that connection that is made when the button is pushed. You have to make that connection. I'd suggest ordering a new button.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
21helpful
3answers
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
Top RCA Tablets & eReaders Experts
 Mikey
Mikey
k24674
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
