Question about Behringer Music
My Behringer ACX1000 keeps blowing the SCR component
    Sergeant:
  • 197 Answers
I would contact a service center here Find Service Center
Posted on Feb 27, 2015
6ya staff
SOURCE:
Bottom speakers not working on vs 1520 burning smell has anyone experience this is it the circuitry thats after blowing and can anyone recommend a place to get parts
In my experience, you won't find parts for this anywhere. Behringer has most part numbers custom designed so they can't be found in cross references which means, a technician cannot replace any components accurately with accurate values to accomplish a full repair. I don't recommend any behringer brand equipment to anyone for this reason. The only repair possible here is through Behringer, which is why they did it that way, and also why they price the junk so cheap that you can replace it cheaper than repairing.
Mar 10, 2014 | Behringer EUROLIVE VS1520 High Performance...
Behringer ms 40
I'm not sure what kind of problem you are having on this but I have been trying fix a Eurolive B215D powered monitor for a friend for over 6 months. I have found that I could fix it in a few hours but, can't find any record of the components used. Standard resistors, caps, and others but certain things like output transistors and more specialized spec components can't crossover to generics for repairs. The only way to get them is through Behringer manufacturer AND they want to sell you a new on instead of fixing the old one. Can't seem to get parts for Behringer equipment. I have talked to other techs that say the same.
Mar 12, 2013 | Behringer Ms40 40w Active Powered Studio...
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
I need a tech in Sonoma or Marin county who service Behringer products
I will give you a hint about selecting a repair facility. You will need to find a repair service that is CAPABLE of troubleshooting to the component level. Replacement modules in this are essentially NOT available from Behringer so one has to replace individual components.
Mar 28, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I have Behringer pmp 2000 mixer but it burned my fuse. How can I buy it?
If the fuse blew do NOT replace it till the unit is serviced or you will burn up more components. These units will blow out from a minimum of three to 30 components when they blow.
There is weak insulation between layers of the power amp circuit board and the arcing destroys a minimum of three transistors and often many more components on the power supply board as well.
I have repaired several of these and it is a lot of work. The power amp module can be had for about $175 but it often takes out the power supply as well.
Jun 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Me too!!!!!
Repaired a PMP5000. Several transistors, a chip, diodes and resistors all destroyed by arc-over in power amp area. Faillure burned the board and had to cut the cancer out and jumper around blown circuit traces. Lot of work and takes great care to restart to avoid blowing components due to bad ones that repair missed.
Jul 03, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer PMH 518 M
I just fix this unit,
1 Nch IRF140N
1 Pch IRF9140N
1 0.1 ohm 3w resistor at one of the mosfets
1 47 ohm 1/4w
1 220ohm 1/4w
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
AC POWER PACK BLOWN
David,   I dont like to be the bearer of bad news, but Behringer dissolved its service/repair center years ago.  In my opinion, this indicates little faith in the profitability of servicing Behringer products.  If the manufacturer wont even repair their own products, I wouldn't buy or use that brand if I had a choice.  Their products are good, WHEN THEY WORK.  They keep their prices low by using inexpensive, disposable quality components.  Most of their products aren't worth repairing.      Here are a few options to find your power supply.  Try Rogue music in New York, NY.  Here is the web address.
www.roguemusic.com
Here is another resource.  DBM pro Audio is an authorized Behringer Repair Center.  They are also in New York.  They will be able to tell you if your part is available from Behringer.  I'm very sorry to inform you of the inferiority of Behringer products.  I think the truth, though it hurts sometimes, is the best teacher.  P.S. if you ever visit DBM... next to the elevator, outside DBM's office is a one yard dumpster, it is always brimming with the carcasses of unrepairable Behringer mixing consoles.      Remember, when buying electronics, you get what you pay for...cheap price = cheap components (and usually headaches down the line) Good luck!  I wish you success on finding your power supply.  Michael Mittelsdorf
www.dbmproaudio.com
See my profile for my qualifications. DBM does all my electronics repair.
Jan 09, 2009 | Behringer Rx 1202fx 12 Channel Line and...
Music Logo
78 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
