Dishwashers Logo
Annette Williams Posted on Feb 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought the 18-piece cookware set from QVC and put them in dishwasher and I noticed scratches inside several of the pans and on handle on one pan. I stopped putting them ib dishwasher and would like to get a replacement set since I had only bought these in the laar couple of months. I have not even finished paying for them yet. I had gitten the gold or copper color set.
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on Feb 27, 2015
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
467365
Points
3209
Not supposed to put in dishwasher
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Mar 03, 2007
SOURCE: Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Anonymous
  • 83 Answers
  • Posted on Dec 07, 2007
SOURCE: hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Mike
  • 677 Answers
  • Posted on Apr 27, 2008
SOURCE: dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Anonymous
  • 42 Answers
  • Posted on Dec 21, 2008
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
I purchased a hard anodized 13 piece cookware set several years ago from J C Penney's. I am very pleased with the cookware, however, I can no longer use the large frying pan. The coating is off and...
Did you use the dishwasher, sometimes they don't like that. If you have the receipt, take it back to JC's, failing that, email their customer support team. This should be covered by the warranty, and outside of warranty. Receipt= take it back.
Nov 01, 2013 • Home
2answers
What are the basics that are included in a cookware set?
It basically is the pots and pans you cook with, with different sized frying pans and saucepans.
Jan 14, 2013 • Home
I purchased the set of pot and pans for my parents 10 years ago. the 6' sause pan coating has come off. I bought the set from QVC. can you replace the pan? you can call me Ms. demandel at 404-788-0700....
Look Carefuly under or handle for number factory anything can identified those pan Then From QVC.com check for service repair then fill up the form for order.. Good Luck
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
