A
Anonymous Posted on Feb 27, 2015
What is a engine sensor on a Xerox phaser 7600
Printer has Engine sensor failure.
James
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Mar 10, 2015
 James
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
17781
Points
27
Unfortunately, your sensor failure will require a replacement from a Xerox technician. You will have to call Xerox or the company you purchased the equipment from to get this resolved.
best way to describe it would be to compare to a cars engine, if your starter fails to work the engine won't run, same for your Xerox device the sensor tells the engine to run.... :o(
This is a major hardware failure on your device.
Error 389.601.00
JM Liabo
English only on Fixya please. We are a North American website and only converse in English.
hello, I have a phaser 7800? the ignition it puts this code, I switched off and on again? the first switch after 5 seconds as indicated. Same thing, nothing, so I wiped the color sensors. The problem persists. What to do?
Call for Xerox Service
https://translate.google.ca/?sl=auto&tl=en&op=translate
Fixes
Xerox Phaser 7800 - Error Code - PrintCopy .info
https://printcopy.info > model=Phaser+7800
Code: 389.601 · Description: RC Sample Block Fail-A1-In. During the A1 (fine adjustment pattern) and C patch detection, the patch at the MOB Sensor In side did .
and more here
https://www.google.com/search?q=Xerox+Phaser+Error+389.601.00
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Engine failure
Hi Zelwe Mwanza
show me error code pls
Help with u2 code on phaser 7300
U2 is an engine EEPROM failure - you'll need to replace the main board to fix that, I'm afraid.
I moved my printer and now I get phaser 7300 power supply failure code u6 on start up. The printer just stops dead.
U6 is a low voltage psu failure. It may be that the power connector to the engine controller board became dislodged during the move. You can check the details in the manual which you can download here.
1helpful
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
2helpful
2answers
004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Xerox phaser 7750gx
Hiya,
Can you be more specific regarding the Engine Logic Board Failure as in is it timing, rom/ram, micor pitch or NVRAM as code 80 is a failure code for
Engine Firmware Halt Failure .
Ta
2answers
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
