Samsung Galaxy Tab 2 Nd Generation 7 8gb Wifi 7" 7.0 Android 4 Tablet Logo
g
grace shirley Posted on Feb 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Who can help me set up a Samsung galaxy tab 4 7.0
I do not know how
micky dee
Level 3:
  • Samsung Master 3,015 Answers
  • Posted on Mar 05, 2015
micky dee
Samsung Master
Level 3:
Answers
3015
Questions
0
Helped
1060780
Points
8762
Have a look through the manual via Samsung support
Download Center Download Software Firmware Drivers Manuals Samsung
William Bailey
Level 2:
Sergeant:
  • Expert 171 Answers
  • Posted on Feb 28, 2015
William Bailey
Expert
Level 2:
Sergeant:
Answers
171
Questions
0
Helped
48733
Points
502
They are very easy. do a factory reset to clean up the per install software and it will walk you thru the set up.
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Not able to get emails incoming to my Samsung galaxy tab 2 ?
Troubleshoot issues related to email on your Samsung ...
support.sprint.com/...email...Samsung-Galaxy-Tab.../...
Sprint CorporationYou may have email issues if you're unable to: Send emails; Receive emails ... Scroll to and tap My Device. ... If your Samsung Galaxy Tab 3 7.0 is still unable to connect to data, ... My rating. 1 2 3 4 5. Give us your comments. Send Cancel ...
Samsung Galaxy Tab 10.1 - Email stops syncing - Android Forum ...
https://www.androidpit.com/.../samsung-galaxy-tab-10-1-email-stops-syn...
Just bought Samsung Galaxy Tab 4 and set up my email to receive from my emailserver. ... Aug 8, 2014 2:14:33 PM via Website. Aug 8, 2014 2:14:33 PM via ...
How to change the email settings on my Samsung Galaxy Tab
support.bell.ca/.../Samsung_Galaxy_Tab.how_to_change_th...
Bell CanadaNote: Entering the wrong mail server settings can stop your Samsung Galaxy Tabfrom sending and/or receiving email. If you can't get the mail server to connect, ...
How to Receive E-mail on the Samsung Galaxy Tab - For ...
Is a samsung galaxy tab 4 7.0 compatible with straighttalk ?
It depends on which model of the Galaxy Tab 4 you have. The unlocked Galaxy Tab 4 3G is compatible with the Straight Talk GSM network and has a SIM card slot. There is a Wi-fi only model which will only talk to a cellular network through a hot-spot device.
I hope this helps.
How do I get started with my Galaxy Tab 3??
http://guide-pdf.blogspot.com/2013/05/samsung-galaxy-tab-3-manual-user-guide.html
Just so you know, all you have to do is Google "Galaxy Tab 3 Manual" and this pops right up. It looks like a PDF download, so you can download it and read it at your leisure. If you want to go even further, print the whole thing out as a reference. Hope this helps. Samsung Galaxy Tab 3 Manual User Guide
2answers
I have received a Galaxy Tab 3 and don't know how to get started. What is the best way to get it set up?
This is a pdf file that you can download that should give you all the info you need to get started with your Galaxy Tab 3. Good luck!
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
